z.Leinbach »
https://forums.nicoclub.com/z-leinbach-u254818.html
Wed Apr 20, 2016 9:08 pm
Well I'm almost certain of a head gasket failure on the drive bank, as I have bubbles in the coolant, did a block test and it turned a teal colour with the quickness, I have 2 cylinders with the next to the same compression and the 3rd with low compression (125ish), granted the car will still pull against one of its own, and the whole of the passenger bank tested at 186 no difference between them
1+ everytime that I have changed the oil, (more then I should but oh wellz) I haven't noticed any milky appearance or metal shavings. Went of a road trip of a total of 8 running hours non stop except for fuel up.
Well as the trip went only had to add a touch of coolant less then half a cup (for safeness) before the home journey, seafoam was added to help clean(buddy got it for his car as a precaution as well.) Tuesday rolls around an I notice some untouched oil at work with cobs on it, ask what up with it, parts say don't know take it, so get home state work change the oil and niiice super dark gold oil, no shavings filings or milky mostly common of head gasket failures, but as I filled up the recycle bucket, I noticed moderate sized chunks of carbon.. this normal for our cars?? An could it be the cause of such low compression??
