Delearious02 »
https://forums.nicoclub.com/delearious02-u13939.html
Thu Mar 15, 2007 3:54 pm
Hello I have been searching for about a hour and 40 min. and i have heard ppl runing 22 lbs of boost from a gt2871r on a stock HG? can anyone back that up? I was looking to run 18-20 lbs if i kept the stock HG. I would upgrade but im told to go from oem HG to a metal HG you have to have the head machined to make sure the surface is perfectly smooth. Again im just wondering what you all have done in order to run higher boost ( as far as the HG is concerned ). And just so you know i have 72# injectors, z32 maf, gt2871r, FMIC and all the other good stuff needed to tune engine/ control boost. But im concerned about this HG issue so thanks for the help in advance.
