Yeah, 264 Toda cams, Greddy mani, and bigger TB. Tuned with a Power FC D-Jetro. I made my peak power @ 7800 rpm which is where we shut it down...... so it was still climbing. I am going to build the head next winter and see what it will do @ 8500 and up.S13FASTBACKSR wrote:400rwhp on pump gas on the 2871r thats really impressive man..i know you have some aftermarket cams with that setup and probably a greddy intake mani? very nice man
No, I have never blown anything on any car I have ever owned. Sorry, I am of no help there.silviabatman wrote:hey broadfield,
did you blow your headgasket and is so, was that pretty much the same set of symptoms you described?....
gonna have them re-deck the head while its out
wow very impressive man...planning on going with solid lifters when you build the head?Broadfield wrote:I made my peak power @ 7800 rpm which is where we shut it down...... so it was still climbing. I am going to build the head next winter and see what it will do @ 8500 and up.
Yes, when you blow a headgasket and overheat you might warp the head (alum) or crack it (iron), but I have always been told that you have to overheat it badly (keep running it when you overheat, etc.) to do either. if you shut it down as soon as you realized it was overheating you probably ddin't do too much damage. You may have gotten slight warpage, but as others have already said, decking it will fix slight warpage (among other things). Take the time to get the head fixed or you will have more problems.travis newberry wrote:dude thats close as hell away... its best not to rush things of that importance
When your talking about get the head resurfaced, do you meen that we need to resurfaced the block to on witch the head sit to?jspek wrote:seriously, get the head resurfaced. it would suck if you put all those parts on the car, just to have to do it all over again. trust me, my sr is sitting in pieces right now, thought it was just a blown hg, and the head is fine except where the gasket took a ****. im torn between what to do, get another head or resurface it. most likely both.
