Head gasket blown on 1986 Nisan 720
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
sterlingstone
Car: 1986 Nissan 720 pickup
I recently had an event while driving down the highway.
There is now a metal ping or pang on deceleration and started running roughly.
I did a compression check, cylinders one and two are near 160 PSIcylinders three and four only read 55psi. Does this sound like a blown head gasket.Note, no while smoke is emitted from the tailpipe and no milky residue in the oil or under the oil fill cap.
Thanks,
[email protected]
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Sure does sound like a blown gasket. Would not show signs on the filler cap or the radiator depending on where the bridge in the gasket is.
comrade_charlie
Car: 1985 720, 1987 300zx, 1985 300zx
If it is a blown headgaskets, They are easy to replace, I did one on a z24 in a d21
The d21 just had bad compression, cant remember if it was none or low like yours, but if 2 are the same bad compression id say its blown between those 2 cylinders like this d21's one was. and it was between 3 and 4 cylinder.
Project Trucker
Car: Datsun 720 pickup
you also might re time the timing belt on the front by aligning the dots
sterlingstone
How is he easiest way..what things must be done to prevent the chain/adjuster from coming apart or falling in the engine?
Thanks.
[email protected]
sterlingstone
Can you see the dots without removing anything?
Project Trucker
go to the timing belt and look at the gear and there should be a little dot on it and adjust it with wrench with the other dot
i can go and check so i can tell you everthing on it if you need
Project Trucker
o and yes you can see the dots without removing anything unless your engine is really dirty
comrade_charlie
When I did it, I just pulled the whole timing cover off, and did the timing after I got the head back on. Didnt have to pull the oil pan or anything like that, just have to go slow.
sterlingstone
Please look, if you would.
Thanks
sterlingstone
Thanks
seang
Car: Ford Fiesta ST
Project Trucker wrote:go to the timing belt and look at the gear and there should be a little dot on it and adjust it with wrench with the other dot
There is no timing belt, what the hell are you talking about
moredunes720
Car: 1985 nissan 720 4x4
yeah, i'm confused on this thread, this motor has a timing chain that has to be suspended to keep the tensioner from getting jacked up. I ran a piece of wire from it and hooked it to the hood hinge. I was in bfe when i fixed the head...so i could not fashion a wooden block like the chilton's suggests. lol the chain ended up fallling down in any way when i trailered it from bfe to my own house in bfe on the other side of the state, even with the wedge. What a learning experience that was.
flinterman2000
A wedge shaped block 2 1/2" at the top would hold the chain and tensioner in place once the engine does not turn. Its easy to remove the head after that.
Return to “Datsun 720”
