DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Wed Mar 03, 2004 10:28 am
I don't understand "stretch bolts", since all bolts stretch under load. BUT if I understand the context correctly, then it sounds like maybe the bolts are actually torqued to the point of yielding. If this is the case, then it makes sense to give the installation requirement as an angle. Because once a bolt begins to yield, the amount of torque you can apply to it will begin to decrease, until finally the bolt breaks. If this is indeed the case, then pay VERY close attention to the FSM instructions, since the load on a bolt is affected by things like lubrication (or roughness) and threadlocker. Don't do anything the manual doesn't say to do. Also, if this is correct, then I don't think it would be prudent to reuse the bolt. That would impart more strain than the initial installation, for which it was designed.
Also, if you use a non-OEM bolt, then these rules probably don't apply, since any non-OEM bolt is probably stronger (maybe weaker?) than OEM. So the initial torquing will not bring it to yielding. But the angle installation should still suffice on these as the preload should be close to as-designed.
EDIT: Does the manual state to retorque the bolts? If not then don't. If the bolts are already yielding, it'll only make them weaker. I think of re-torquing as a technique used with RTV seals back in the dark ages. Current RTV products are much better than before and don't shrink like their predecessors. Thus retorquing after 24 hours is usually not needed for RTV anymore.
