I am Technoman wrote:The KA24DE has hydraulic lifters if that what you want to call them and multi chains. Under the shim is the hydraulic lifter. and spring, retainer and valve.......
What hydraulic lifters? If it used hydraulic lifters, you wouldn't need shims.
The KA has direct actuated valves which are lighter and require less spring pressure to keep the valves from floating. But they are not hydraulic. Hydraulic lifters are those that self adjust the valve lash through oil pressure. The SOHC KA has hydraulic lifters. Run a freshly built SOHC KA for the first time and you will get tons of valve noise. About 20 minutes of idle and then the valve noise will go away as the oil makes it's way into the lifters and reduces to the valve lash to acceptable levels.
