Q45Tech has stated a couple of times now that the VH doesn't have the greatest cooling at 700HP+
Well I'm wondering whether there isn't a relatively simple fix for this.
Looking at the 'water jacket to head' holes in the head gaskets, they're tiny 4mm-ish holes, and when compared to the large oval shaped coolant galleries that actually pass from the block to the heads which these little holes gasket up... they look like a bottleneck for coolant flow. I'm not sure on the effect of enlarging these holes in the gasket, but it's a potential avenue to guarantee improved coolant flow at high temperature operation.
Anyone care to theorise on potential pros & cons of said modification? (Assuming you're not going to damage the gasket, or that you're using a custom copper gasket, etc.)
