If you put the headgasket on backwards, this will happen. The only way this thing will leak is that if your head or deck is warped. Remember, these engines were decked from factory and if that was the 1st time you opened the head up. It is good idea to to get them machined, but not always necessary.rico05 wrote:Well, I FINALLY got the time to button everything up. Looks like my gamble failed. The Cometic did not work b/c I was stupid and didn't machine the head. I thoroughly cleaned it but still no go. Looks like I have to pull it all apart and wait until who knows when to get the money to get a stock hg and all the fluids etc.
Any thoughts? Could it be anything other than a bad seal? It is leaking oil (a LOT) from right above the coolant return on the block. I may pull off the valve covers and see if those 2 studs are the correct torque, but I am pretty sure they are. BTW, if you happen to be close to Texas, I may be selling, but not parting out, the car.
You shouldnt reuse the OEM headstuds. They are torque-to-yield meaning they stretch when they are tourqed down.rico05 wrote:Well, here is another thought. My buddy mentioned that Hondas have a really high torque spec for reused head studs. This is the first time this head has been off, and they are the standard studs. I torqued them down to 76ft/lb (lowest of the stock specs). Should I consider new studs? Or going up to 88ft/lb (high spec in the FSM IIRC) Any thoughts are appreciated.
standard bolts are NOT stretch bolts the FSM does NOT say they need to be replaced. The general opinion is they should be used no more than 3 times.c-rad wrote:You shouldnt reuse the OEM headstuds. They are torque-to-yield meaning they stretch when they are tourqed down.
You are such a silly bastard.rico05 wrote:MUWAHAHAHAHAHAHHAHAHAHAHA!!!!
IT'S ALIVE! IT'S ALIVE!!!!Seems that the #4 in the retightening (the bolt right where the leak was) was not all the way tight. It was still at 22ft/lb! Tightened her down, and no leak. No smoke from exhaust, so no fluids in the combustion chamber! Now, I just need to replace that ~qt of oil that she hemmoraged, reset the timing, and boost off down the road!! Thanks for all the help guys!!!
