HC too high at Idle
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
So I took her to the Nazi board of emissions today. I passed everything except HC at Idle. The only codes I have are a knock sensor and A/T code.
Any suggestions to get it passing. I warmed the CAT up real good before testing and ran premium fuel.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
how far off were you?
Carl H
fix the knock sensor...a knock code will cause the engine to run SILLY rich.trust me on this, my vh had the knock code for ages and it would smell like raw fuel if you stood behind it once i fixed it it ran noticably leaner.
newbissan-tech
Car: 96 vh45 swapped 240sx SOLD, 2011 frontier pro4x SOLD, 08' Altima SOLD, 2006 TITAN, 2012 SUBURBAN FOR THE FAM.
im a technician at a local dealer and im going to second that motion!
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
I also had an ECT code. I threw another ECT on it and got rid of that.
I tried to test the knock sensors through the harness. I could not get a resistance reading on one. I assume that means it is dead?
I also checked the resistance on the injectors and came up with two that were in the 15.8 range. Specs are supposed to be 10-14 but these injectors are brand new! is 15.8 so far out of range that it would case a problem?
It also won't hold a steady idle. Sometimes it will come right to 900 rpm and hold there. Other times it wants to hold at 1100 or 1500.
HC at idle needs to be <220 and I was around 550
Modified by LEMHEAD16 at 2:52 PM 8/3/2009
Carl H
it seems to be accepted fact that knock sensors do not last on these engines...fwiw you can use knock sensors from a 97 vh41 on the v45 with a plug swap and the addtion of an external ground, this is what i did on my vh and the sensors were 50$ total!
Return to “VH45DE / VK45DE / VK56DE Forum”
