dvdswan »
https://forums.nicoclub.com/dvdswan-u155921.html
Mon Mar 15, 2010 4:10 pm
well, for the wipers, I would grab the whole column that had both wipers and cruise, the intermittent wiper switch, brown box on the pass. firewall in the engine compartment including the wiring to it (at least the connector), and possibly the motor.
for the CC, activation switch on the dash, module under dr. seat, servo on the pass. firewall, throttle linkage as well as the connector on the t-body, vacuum lines, wiring connectors, the more you grab the easier it will be to install. thats all I can think of off the top of my head. if you look at a pathy FSM it will tell you all the pieces for sure.
hope this helps. I know there is a forum that has older FSMs but cant think of it. I want to say its a frontier forum.
