Hazing headlight covers
PGrated
The other day when I was washing the car, I noticed a slight haze starting around the top of the headdlight covers. It is definitely on the inside of the assembly. I was just wondering if anyone is getting this to any extent. Right now it is not terrible, but I don't know if it will get any worse. And, if it does what should be done about it. I'm very reluctant to even try to take them apart since I would think that it is a sealed assembly and would invite other problems if opened up.
Thanks in advance for the help.
pgrated.
joe603
Car: 2014 Durango R/T
Take it to the dealer, it should be covered under the factory warranty.
manny65
Car: '03 G35 6MT Coupe
I had the same problem on my '03 Coupe.I took it to the dealer, expecting to have the lenses replaced under warranty.Unbelieveably, the service manager proved to me that the hazing is on the OUTSIDE of the lens.A good plastic polish such as Meguiar's will make them look like new.
Q451990
You may be on to something here... I had what I thought was hazing, but corrected it with some Novus plastic cleaner. I figured later on the haze starts on the inside though...
Heath
PGrated
I will take a look at it more closely and try some polish on it to see if it makes a difference. I will post my results and let you know what happens.
pgrated
PGrated
Okay, I came home today and tried using a good polish on the lenses...and to my surprise, the haze was gone!! Manny, you were right, the haze was on the outside, not on the inside! Well, I guess the only way I'm going to get projectors is to trade in my '04 to an '06 Anyway, as they say: As our circle of knowledge increases, so does the circumference of the unknown (probably exponentially).
Take care All!!
Road Ruler
Car: G35 sedan prem
Here is a link with some more additional info....
http://www.g35.ca/board/index.php?showtopic=3626
pae9132
Car: Modified 03 V35
I know this is old but I have a new tip
I was using the mothers plastic polish but the haze didn't take long to come back....so....I took a chance and used my rubbing compound on the headlights and then the plastic polish...the rubbing compound just acts as a slightly more aggresive polish and the plastic polish finishes it off....well my headlights look better then ever and the lights aren't hazing up like they used to
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
I've used a 3M plastic polish on headlights before and was amazed at the difference it made! Got mine at Napa
joe603
If you use a polish and the haze doesn't go away, its a crack in the lens.
