CakeDaddy »
https://forums.nicoclub.com/cakedaddy-u38666.html
Fri Jun 08, 2007 3:32 am
My left headlight lens had a little haze on the to right corner, but nothing major so I purchased this stuff called "headlight lens restorer by Blue Magic" I applied 5 application and used a buffer in between each app and what a difference, no more haze, plus the lenses are more clear and clean . I turned the headlights on to make sure it was haze free. It looks as if I used a hi grit sand paper on them. I've actually used hi grit sand paper on a previous car, so I remember the smooth clear finish. Definately(sp) use a hi speed buffer then follow over it with a soft towel to remove any left over resudue.
I've considered using some 3m rubbing compound to knock out those fine lines on the lenses. What do you all think?
Modified by CakeDaddy at 7:43 AM 6/8/2007
