pfarmer wrote:
Or maybe 'Mirror Glaze'.
Now what is the haze caused from? Make sure you are carefull in its removal so you remove whatever the haze is without scratching the lights.
Perry
I mention this since it is possible for the 'haze' to be abrasive. So regardless of what product you use you can scratch the lights with the 'haze' itself. Once removed, even very gently and the 'haze' may have been a little corrosive which may require some additional polishing.
This brings up the topic of the 'invisible bra' on my car. While I not 100% satisfied with it, the one place that seems to benefits is its application on the headlights. That is if their removal doesn't leave behind some nasties of theirs. If the lights have a coat of 'haze' on them, then remove the 'invisible bra' off the lights and replace it. The car was fairly expensive to do, but the kit for just the lights is fairly cheap and unlike on various parts of the car very invisible on the lights. Maybe worth looking into since it already nailed you once.
Perry
