hay guys im new and this is my CA
SLIPIN
Car: S13 200sx
hey people im all the way from NEW ZEALAND and just found your web site i own a s13 200sx with a CA18DET in it. its great to have a forum all about CA's heres a couple of pics of my car and my CA_POWER!!!!!!! motor
and my dyno
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
Nice car, what are the specs?
I love the front hole you cut in your bumper and also your DRIFTAAAA plate heh
boost_boy
SLIPIN wrote:hey people im all the way from NEW ZEALAND and just found your web site i own a s13 200sx with a CA18DET in it. its great to have a forum all about CA's heres a couple of pics of my car and my CA_POWER!!!!!!! motor
and my dyno
Welcome "SLIPIN" to the NICO CA forum. One of the biggest CA forums on the net and one of roughest/toughest as well. I'll be the first to say your car looks sharp, clean, and powerful. Your dyno #s are spot-on as to where your car should be for the size turbo you have. We would be interested to know what are the specs of your vehicle. We look forward too seeing more of your car and it's performance and once again "Welcome".................
Dee
SLIPIN
Car: S13 200sx
hi thanks for the warm welcome hahaha the spec of my motor well her it goes
Custom made turbo rated up to 600hp same size as a T66Port and polished (flow bench tested) head done buy leading edge cylinder heads Heavy duty valve springs and new valves in the headCam’s inlet 278’ Exhaust HKS 256’Tomei adjustable cam gears IN/EX Ross forged pistons Shot penned rods A polished and balanced crank and all new race bearings 500hp walbro fuel pump 710cc injectorsmallipassi fuel pressure regulatorZ32 airflow meter Trust type R blow off valve All aluminum custom intercooler pipingCustom FMICCustom top mount headers Custom 1.5mm steel head gasketCustom made 5 puk heavy duty clutch made buy exedy race clutches in OZ Custom made steel lightened flywheel Custom made 3 inch dump pipe straight off turboCustom made 3 inch exhaust all the way through 38mm delta gate mark 2 wastegate60mm Enlarged throttle body Apex’i AVC-R electronic boost controller Apex’I AP Engineered CA18DET Power FC Samco sport blue intercooler joiners and 3 inch into 4inch turbo joinerRadiator has been cleaned and new top hats put on New water pumpNew battery All new beltsBrand new DBA slotted and cross drilled brakes Brand new up graded brake pads Adjustable coilover shocks - hot bits (this is the brand name there not stolen) 17in x 7.5in TE37 Replicas with 215’s on them This is all I can remember of the top of my head but I know I’ve missed a few things
the tune that its in at the moment is only a half tune it was tuned on 96octane pump gas and it had only 10km "6miles" on the motor when we put it on the dyno so we only took it up to 7000rpm and 18psi when i take her back im hopeing for 300rwkw @ 8500rpm and 25-26psi of boost
float_6969
Beautiful. Very nice ride. Glad to see you on here!!!
undertaker
Car: C33
cool car I saw you run at the nats this year, nice to see another Kiwi on here too
zero_gripS13
Car: soon to be 95 s14 hopefully
kw= how much hp??? anyone know how to convert?
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
zero_gripS13 wrote:kw= how much hp??? anyone know how to convert?
HP = kW / 0.746
It's about 319HP.
Very nice numbers BTW, and welcome!
themadscientist
very clean car, it's refreshing to see no garish stickers, just a clean car
rico05
Car: 1992 RMS13 w/ CA18DET
Good gravy! Nice to see what can happen with a CA when parts/tuners are easier to come by (and you have real money to spend LOL)! Awesome car!
