I can definitely do that. I figured it was a normal condition of a higher performance pad. Just wanted some confirmation. I'll drown out the squeals with my new BRM exhaust when I get it.Exar-Kun wrote:if so..I reccomend three steps for fixing squaling high performance brake systems:1.get2.over3. it
Other than quieting the pads down, would there be any benefit to this? The noise itself doesn't bother me, as long as everything else looks OK.toptechracing wrote:If it's just a slight squeek on application I would pull the pads back out and put a 45 degree chamfer on the lead and trailing edges of the pad.
Grant,Grant@tirerack wrote:Another source of noise can be from old spring clips/hardware. It's always a good idea to replace all of the little hardware pieces. They are exposed to a lot of heat and may not work as well to keep the pads in place when you are not using the brakes.
I'm gonna go with extra brake goo (lol) and if that doesn't stop the squeal, then screw it...I give up.skatanic28 wrote:i just threw the pads on how they came in the box, and put some of that brake goo on the back of the pads. i dont get any squeel, but ive heard of other people saying the hps can be noisy...
i swear sometimes i think im still 5 years oldBadMojo wrote:I'm gonna go with extra brake goo (lol) and if that doesn't stop the squeal, then screw it...I give up.
that is my exact setup, and it kicks ***. they just wont fade given my driving style, and the pedal feel is sooo much better than stock.BadMojo wrote:I can't wait to get new rear calipers installed (thanks, Alan) and get the SPL Stainless lines and Hawk Pads on the rear, along with the ATE Super Blue fluid.
i tossed all the old hardware. the pads already had the shims on them, so i just put em right onto the retaining clips. i seriously used a ton of that stuff though, i can still see the red now.BadMojo wrote:***Skatanic, did you re-use your OE hardware? Did you put a shim or a shim cover on the existing pads, or when you say you just put them on did you throw out all your old hardware?
So, you actually replaced the dust seals on the calipers and cleaned them (the calipers)? Did you clean the calipers with brake fluid and then lube them with some of that caliper lube stuff that Permatex makes?s13sr20chris wrote:hawk hps front and rear, cleaned and lubed caliper slides, new caliper slide boots, new oe front rotors, turned rear rotors, no goo, no shims
i have abs(no worky) so i have slightly bigger front calipers and rotors(too much front brake bias)
no noise, no fade(on the street), and hard pedal
i replaced the rubber boots that fit over the caliper slides on the caliper bracket(aka torque member). the old ones were torn and the slides were sticking. i cleaned the slides(aka pins) and lubed them with nissan "pbc grease". the pbc stands for lead and copper. less than one liter bottle costs like $60. i have it at work for that dealership quality brake job(read warranty only )i did not disassemble the calipers themselves at this time. they work good and i dont feel like spending the $30 on a set of seals.BadMojo wrote:
Thanks, man...I can definitely do that. My boots were in good shape, but I can lube up the slide pins. I've got some lithium grease in the garage.skatanic28 wrote:i took off the boots and cleaned and lubed the slide pins as well, but with just ordinary lithium grease.
