having trouble with stabilizing my ka
neogeoss4
Car: 1991 Nissan 240SX Hatchback Nismo Edition
i got my head rebuilt, piston rings replaced, hand cleaned fuel injectors, we put it all back together me and my boys and we cant manage to stabilize the engine... it cranks but it shakes and wont stay on... well it's been a few days and its always the same response, the timing is adjusted perfectly to jimwolf specs, but when we crank it and try to adjust the distributor timing, the engine is too unstable, we hafto give it a lot of acceleration just in order to keep it running @ 700 RPM... i REALLY need some help ... please
Morph
Car: 91 Sr Powered Coupe
Ecu throwing out any codes?
spank044
Car: 1992 240sx with a Supercharged 350Z VQ for a HEART!
What kind of mods?
matt4pl
Car: cars, anything fast, graphic design, lots of stuff
possibly a tooth off on the distributor. also check for vacuum leaks
Chezedik
Car: 1991 Nissan 240sx
Sounds like you have the cams a bit off, what are your compression and vacuum numbers looking like?
EDIT: Also, you cannot set dizzy timing by cranking on it. Just pull it out, set the timing marks and stab it. Then, when you get it running, use the timing light.
