Having trouble with new rims
Jonnyk300zx
Car: 1990 300zx na
So i put 19" rims on today and its barely missing the fender. The problem im having is i cant turn my left wheel right without it hitting the bumper! Can some please help me figure this out????? Thanx!
helio300zx
Car: 300zx Twin turbo
only on 1 side? check the control arm
Jonnyk300zx
Car: 1990 300zx na
helio300zx wrote:only on 1 side? check the control arm
I havent done the other side but the other right now with the stock rims on, its close to my bumper also! Thanx, ill check that out tomorrow.
300zxstanced
Car: 1992 300zx tt
2008 Ram Hemi
2008 X5 4.8
2007 Camry
2007 Hayabusa
19's will fit but you will probably need to change your lower control arms to adjustable lower control arms. Also what size tires do you have on the front?
Jonnyk300zx
Car: 1990 300zx na
300zxstanced wrote:19's will fit but you will probably need to change your lower control arms to adjustable lower control arms. Also what size tires do you have on the front?
How much you think doing that is gonna cost me?? Sweat ride man! But i was running 245/40 all arpund but just change my front to 235/35
buloushie
Car: 1991 300zx 5speed 2+2 NA
A little more info would help. IE wheel size and offset,tire size. Plus you do not need adj lower control arms on a Z. Most likely wrong offset for the front. You want in the 30 range A good size for the front is 19-9 or 19-8.5 run a tire size around 235-35-19 to 255-35-19. Hope that helps
Jonnyk300zx
Car: 1990 300zx na
buloushie wrote:A little more info would help. IE wheel size and offset,tire size. Plus you do not need adj lower control arms on a Z. Most likely wrong offset for the front. You want in the 30 range A good size for the front is 19-9 or 19-8.5 run a tire size around 235-35-19 to 255-35-19. Hope that helps
Thanx man. My rims are 19x8.5. Not aure about the offset.
300zxstanced
Car: 1992 300zx tt
2008 Ram Hemi
2008 X5 4.8
2007 Camry
2007 Hayabusa
I dont believe offset is the issue here, I saw the pic you posted in your other post. It looks like your car is lowered and the front wheel actually touches the bumper. The only way to push it back to its proper postion is (1) adjustable tension rod Megan racing has nice ones for the Z and there not bad for the money, or (2) your lower control arm may have broken from where your tension rod bolts to the lower arm, you will have to replace it if it is broken.
