Hello,
So i purchased my rfls from z1 as a kit. Everything was installed properly and checked and rechecked. Im getting a little compressor surge at low rpms. Though when I drive the car hard it blows off fine. 1st and 2nd is the only gears I can hear them blow off. 3rd 4rth and 5th all I hear is compressor surge
. I removed all the washers from inside. and checked for all leaks. Im getting good vaccum to the bov's. The car idles fine. Im not sure if these are made for higher boost application, but Ive seen these on stock wrx's and 240's running fine. For mods I have full exhaust and an intake. I have them to atmosphere not recirculating. Thanks please any input would be great. Would it be possible that i need to put them closer to the throttle body????? Ive seen z32's with hard pipes from the throttle body to the black tube leading on the side of the radiator?
