The black links are just there for reference. I would try to match it up with those links those because you never know if someone else might need them not knowing you just placed the timing chain back without aligning the links.boro drift wrote:Wait a minute, wait a minute, are you trying to line up the bright links in the chain? That **** doesn't matter. The only thing you need to pay attention to is the the timing mark on the crank pulley, and the marks on the cam gears.
with the right tools you can get all the 12mm bolts. its kinda a pain in the *** but if you really want to get that chain out then go for itORICLE wrote:Thanks for the information. So do I need to do anything to gain access to the second oil pan. The crossmember is in the way? Thanks again.
