s13drft89 »
https://forums.nicoclub.com/s13drft89-u31033.html
Mon Dec 05, 2005 3:48 pm
Well i got everything in, here is my setup ssa mani, garrett turbo internel wastegated, smic intercooler, cutom piping, 370cc injectors, stock maf, and apexi safc, and a generic BOV also i took of my egr, and replaced it with a block plate, and capped all the line going to it with screw and silicone, so it wont leak for sure. Well the car starts up fine, idles a little high, but i believe thats from the throttle cable, well i go out and try to rev the car, it only wants to rev between 2500-3000 rpms, my boost gauge reads 20 vacuum on idle, and when i rev is to arouns 2000 rpms it goes closer to 0 (boost side), iam running my boost gauge and bov from form the FPR, and my wastegate from the housing of the turbo, where it has a fitting from garrett. I dont know what to do, iam stuck, and ideas or suggestions, also my check engine light went on, i did the check for the code, and it read out only one code which was 33 which would be o2 sensor, but i dont think this is the reason why the car cant pass through 3k rpms, also get this when ever i barley just turn on the car, i push on the car it revs past 3k, and i then let the rpm's drop and i try it again and when it hits 2500-3000rpms it gets stuck their any help please thanks my aim name is s13drft89 thanks
