Having trouble starting up Armada.
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
Ramonesfreak2010
Car: 1993 240sx Hatch
Hey everyone. My cousin owns a 2004 Pathfinder Armada. Recently he has been having trouble starting up his car. He changed the battery, got it tested, tested the starter, and even replaced the terminals. When we were at Napa, the counter guy told us to check the starter relay. We popped the fuse boxes in the bay and looked for the starter relay, but couldn't find anything. Anyone want to point me in the right direction, so I can test it with a multimeter? I've tried searching the FSM, but couldn't really find anything. :gotme Any help will be appreciated!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
If I'm reading the wiring diagram on SC-11 correctly, it looks like the starter relay is within the transmission control module. :confused:
Is the "SECURITY" light flashing or solid after a failed start?
PJam68
Car: 2007 Nissan Armada
Flowmaster
Hello all. I thought for sure there would be no hope for my starting problem but maybe my problem will be solved by one of you. I bought my 07 last fall and randomly it will not start. If you turn it over and turn it off 3-4 times it will then start. I cant find a pattern tied to weather or any driver. My mechanic drove it all day and can't find anything wrong, when I went to pick it up......it didn't start. I have put my diagnostic tool on it right when it wouldn't start one time and it is not throwing any codes. My wife is not amussed and wants it fixed! Thanks for listening.
PJam68
Flowmaster
C-Kwik
It might be helpful if you describe exactly what it is doing. Is the starter motor engaging? Does it just click? Does it click rapidly?
Return to “Armada Forum / QX56 Forum / QX80 Forum”
