DONE!!!! it runs, idles and goes to redline. my only problem now is a low idle. its at about 450 rpms how do i get it to 750rpmsBwana wrote:Well, get all that stuff hooked up and try again. I know for a fact that they'll barely run with the intake disconnected. My 240 is awaiting a rb25 transplant at the moment, but the MG is in good form. I take it up to FtC to do a little cruising every now and again.
NSR A32 wrote:Check your Idle Air Control Valve. Could be sticking slightly closed causing the low RPM idle.
