I have 94 Infiniti q45 that ive Had reliability issues with for the whole year I’ve owned it. It’s always had an issue of randomly getting stuck at an rpm. Recently I can’t get it to stay on. It’ll start and rumble right under 500rpms and shut off. If I give it gas it won’t do anything just stays on at that low rpms and shuts off as soon as I let off. I’ve replaced fuel injector, spark plugs, fuel lines, fuel pump, fuel relay, fuel filter, upgraded the ignition coils to the Ones off vhperformance, it running okay after replacing a bunch of vacuum lines and fuel lines and the lower and upper intake gaskets, after it would just idle super rough and shake at stops. The only thing I didn’t replace was the injector seals bcus i couldn’t find where to buy them at; they were a bit shredded. But later on once I drove it home I sprayed the maf sensor connecter with maf cleaner and it started not wanting to start and and last time I got it to rev up it shot a flame while dying down from 7k. Plz help
I bought this thing to daily and having been having issues with it for a while now, one main thing I’venever been able to fix the the issue of it getting stuck at a certain rpm
