cjs37xs »
https://forums.nicoclub.com/cjs37xs-u144430.html
Wed Oct 14, 2009 1:13 pm
In your manual (ahem) it tells you all this.
And part of me wants to just say go check out your manual...but that's just not very neighborly, is it? Ok, you're not my neighbor, but your my G37 brother...
You cannot close the windows with the intelligent key...you can open them, as you have already found out.
You can open & close the windows using the 'mechanical' key. put the key in the keyhole, and turn it towards the rear of the car (unlock) for more than 1 second, and the window will open...and continue to open while the key is turned.
This also works for locking & rolling UP the windows. If you turn the key to lock it, then keep holding it in that position & after 1 second the windows will roll up & continue to do so as long as the key is turned in the lock direction.
Welcome to the forum...I'm, new too...but I've read my manual (sorry )
