Dustin792 »
https://forums.nicoclub.com/dustin792-u125400.html
Tue Sep 08, 2009 7:29 am
Hello everyone , i just finished installing everything back in order on my ka24de. The headgasket needed to be replaced, i have no emissions on my vehicle. anyways iv'e looked at the vacuum diagrams but im still not sure about these two components , the swirl control valve and the fuel pressure regulator. do these components need to be installed with vacuum to run and if they do where should they be installed. also should i just plug the line coming from the egr. the engine will run for about 10 secs then it just bogs out. iv'e done the timing on this motor before so im pretty sure the timing is correct. i had the motor in tdc with distibutor rotor pointing at 1. i also want to be sure about the fuel lines, i installed the line coming from the filter to the right fuel rail connection and the return line to the left fuel rail connection.
