WAbernethy »
https://forums.nicoclub.com/wabernethy-u849.html
Fri May 28, 2004 2:56 am
I recently picked up a universal BTM (not the ignition, just the timing controller) from MSD, got it all installed and now my car runs like ****. First, I installed the BTM and found out that my tach didn't work, so I ordered that tach adapter. Got that installed and now I'm having problems with it sputtering under boost. I tried disconnecting first the BTM and then the tach adapter and found that the problem only went away after removing the tach adapter. I've spent some time with MSD on the phone and they don't seem to know what's going on. They had me check voltages at the coil both at idle and while driving under boost to see if it dropped, which it didn't. And it dosen't matter if I have the little retard knob turned all the way to 0 either. And I've also tried it with and without the diode. The only thing that MSD could tell me to change to make it go away would be re-gapping my plugs to a smaller gap. I feel like that is a band-aid fix and is not really getting at what's really the matter. They're at about .032 now and they wanted me to go to .025 or something. If it works without the BTM at that gap, then why would I need to lower the gap after installing it? Anyone got any experience with one of these setups?
