Having some problems.
user name!
Car: 89" 240sx coupe DE swap. =D
Well im having a couple of problems with my coupe. It shakes, is ALOT slower, its obnoxiously louder than before, and feels like its ready to just give up. I pulled all the spark plug wires and cylinder 1 makes no change when i pull it out. I was guessing that i have a bad spark so when i pulled them out to replace them there was oil on all four. So now im not really sure what might be the problem. Thats where you guys come in. Anybody have any ideas?
-Chris
P.S. Im currently internet..less so i wont be able to reply until the 20th (Ill have dsl by then.).
user name!
Finally, I have working internet. But wow are you guys slacking? Nobody has any ideas? Has nico changed these past months? tisk tisk.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
change the seals on the spark plug tubes in the v/c. then get some new plugs/wires and check it again. have you tested to see if the wire is at least getting spark?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Moving to tech to get this guy some answers!
user name!
srpowered240sx wrote:change the seals on the spark plug tubes in the v/c. then get some new plugs/wires and check it again. have you tested to see if the wire is at least getting spark?
Cool, Ill try that out and no i havent. How should i check that?
Hijacker wrote:Moving to tech to get this guy some answers!
Haha thanks.
srpowered240sx
user name! wrote:Cool, Ill try that out and no i havent. How should i check that?Haha thanks.
get a spark plug wire tester. or just use the ol screwdriver in the end of the wire trick. i would get one of these....
or better yet....
because you can use it on either end of the plug wire.
user name!
Ohh. Alright thanks. My brother has one so ill just wait till he brings it over.
