KASilvia90 »
https://forums.nicoclub.com/kasilvia90-u28447.html
Wed Jan 10, 2007 10:44 pm
Alright here is the update:I replaced the previously mentioned relay and I have power at my coil again but it isnt starting! , it is just turning and turning but nothing, no popping noises, just turning.
I have fuel because i keep flooding it since I have reverted to the paranoid "fiddle fiddle, test" method.I have sparkI should have air, I cant see why I wouldnt, I checked for vacuum leaks, I guess I could have missed something really small but I've had leaks before and it starts or pops some.
The Cam/Crank timing is perfect. No contact or anything. I have triple checked it and it is fine. I also have triple checked the ignition timing, it is fine but its acting like its 180 off or something! Cables are on correctly, brand new cap/rotor and they are contacting because the points on the cap have slight usage wear showing from the cranking.
I pulled my dist. off, with it on ACC and with the cas hooked up. Rotated the shaft, I heard in this repitable sound "fuse panel area relay click, then a loud click from the injector area (all 4 firing at once..?) then the fuel pump kinda pressures up for a second and repearts. All along with some random inconsistant popping from the coil lead->ground. I have an MSD system but is bypassed, running straight from harness to coil.
I am also NOT for some reason getting ANY sign of life from my gauge cluster. I am sure the speedo and what not are working, but the tach isnt moving at all when i crank. It should be at 250+, no?
I checked my compression, cold/dry : 68/69/68/130. Now that doesnt sound right but I figure its because my oil is basically water until tomorrow (i had poured flush into it expecting it to start and its deteriorated the oil, i didnt think about that until today) and I think I am cylinder washing my walls. I will add 1 tea or table? spoon of oil in and test a cold wet tomorrow.
I havent seen a code yet on the ECU and it recieves a start signal. This has me baffled, my car has been down for a month now. 2wks longer than it should be beause of this bug Icant find.
All I can say is I MISS MY CAR...and my girlfriend
