having problems with my sr20
DawgMode
Car: 180sx
wassup,a couple months ago i spun a rod bearing in my #3 cyl.....i pulled the motor, put in a new crank and changed all the rest of the bearings(except the main bearings).......now that it is back up and running and im having a few problems....A)the car is constantly back firing when i let off the throttle(but it doesnt stall out)B)i have this japanese fuel controller and the car breaks up(spudders) under hard Acceleration when i have it at factory settings...so in order for it to run properly i have to set it to almost full rich...whats wrong
i tried playing with the timing but i had no success
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I'd say you should either get on a dyno or buy a wideband o2 sensor so you can see what is happening with your air/fuel ratios.
hondahunter180
Car: 2003 audi a4 - 1969 bmw 2002 - 1990 s13 (sold)
my friends sr had the same sputtering problem under hard acceleration and it turned out to be vacuum lines in the wrong order. sence you have recently pulled your engine, i would go through and check for that.
VitaminT
Car: 93 240sx SE
I am guessing you have checked you timing and properly gapped your plugs?
DawgMode
Car: 180sx
im gonna change my plugs today and see what happens
