having problems starting my 1994 infiniti q45. must put gas pedal down to start
slocumnb
Car: q45 i35
having problems starting my 1994 infiniti q45. must put gas pedal down to start. has anyone else had this prob. engine light on. please help.
qship96
Car: 1996 Infiniti Q45
We could throw out guesses all day, or you could take a few minutes to read what codes triggered your check engine light and know for sure? One way is much more accurate than the next.
Q45tech
When you floor accelerator during cranking you are signalling ecu to shut off fuel because you want the equivalent of choking a carbeurator on a flooded engine.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
slocumnb wrote:engine light on. please help.
So help us by giving us a maintenance history and a report of condition.
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
Having the same issue right now... although i usually don't have to hit the gas to start the vehicle, but often enough.
My problem is that the MAF (Mass Air Flow) sensor is going bad.
The car struggles to stay on or start. The car shut off on me in the middle of the intersection while making a left turn.
I cleaned the MAF, worked well for a little bit. Eventually I have to replace it. Right now I have hooked up the K&N Air Intake and thats whats keeping it from turning off or idling low.
Could mean gas is getting past the injector O-rings. That was the case on my Maxima.
