So i turboed my 240 last night, kinda getto job, but it worked, kinda... for a little while...
Everything went together okay, car ran fine but only boosted to 2-3-4 psi and it would spool really high arond 4000-4500rpm..
anyways... i tried ****ing with the wastegate, but broke it... then fixed it, and tried things again.. this time to boost... ****ed arond some more... after a while i decided to see if the turbo was still spinning...
damn it... it had sized, thats why no boost... so i check to see if the oil feed line was suppling the oil.. yup it was fine... what do you think happend, the turbo seemed to spin freely when i put it in.. why did it not build boost and why did it spool sp high?.. anyways i'll try my other turbo tomorrow..:thinker hope it'll be okay
