oneilldn »
https://forums.nicoclub.com/oneilldn-u175847.html
Tue Jan 11, 2011 10:22 am
Hell all,
So I decided to replace my valve cover gaskets and spark plugs on my 97 QX4, let me tell you, I'll never do that again, I didn't know it was going to be so hard (for me) too many cable, hoses, etc... Still, i got everything back together. But now it's running a little bid ruff.
Things I did:
I replaced the spark plugs, the ones I got at the auto part were NGK V-Power, but I noticed that the ones I took off the truck were NGK platinum. I called the local infiniti service department and they told me that the NGK V-Power were factory replacement; true? But no idea if this is the problem.
I also removed the distributor cap, but didn't touch anything inside; did I mess something up removing it? Does the time needs to be adjusted?
Also, My idle its crazy now, I was reading something about idle relearn, but they only thing I found was the 2001 procedure; I follow that one and it worked only for a few hours, then idle got crazy again.
And last, its shifting gears really hard ( I think is cuz the rev/idle is high?).
I would really appreciate you guys help/advise.
