having issues with my iddle rpms
Sp3cToR_240sx
Car: 1990 Nissan 240sx Hatch
i think that the idle rpm on a 90 single cam 240 is 700rpm...mine is always at 1000rpm and sumtimes even up to 1500rpm if the car has been running for bout more than an hour... sumtimes the car boggles when i open the throtle to start driving... im thinking maybe i need to c the timing on my distributor cap? maybe change the angle and stuff but idk? wut do u guyz/galz have to say or know bout this issue?
Modified by Sp3cToR_240sx at 1:36 AM 9/2/2008
hellboy006
hrrmmm... yeah sounds familiar... my problem is similar, you can adjust the idle screw (on the back of the intake mani) if you think that will fix your problem... unless your problem is like mine in the way that the idle fluctuates alot (mine goes from about 1000 to 500 or less, almost dies)... in which case i dont know what to tell you cause i havent figured it out yet... im thinking the IACV might be messed up? idk..
240goober
Car: 240sx
Got that problem too. I was told to check the timing on the distributor as well, so that is most likely all you have to do. If that doesn't work, then idk
Sp3cToR_240sx
thanks for the replies! i think im gonna have to mess with the distributor angle to have it right! thats the only thing i can think off since i noticed that issue but im still in doubt!
hellboy006
ever get anything worked out? I know my timing is ok... its set to about +19 (stock is +15... i run 93 octane) i just bought a new cap and rotor kit and a new coolant temp sensor for the ecu (i heard these can cause weird idle problems) havent put them on yet though.
Oh and by the way the fsm says idle should be 750 + or - 50... so yes 700 to 800 is normal.
snowyred180
Car: 1994 Nissan 300zx TT, 1995 Acura Integra GS-R, 1994 Honda Prelude
Check the IAA unit. Its located by the firewall under the intake manifold. The adjestment screw is on this unit. I know they have a lot of problems with this in DOHC models. There's a thing on it on the old FAQ:
http://www.240sx.org/faq/index.html
Also search for it...
hellboy006
hey thanks for the link man, lots of good stuff in there. Yeah your right, it looks like 99% of all cases point to the IAA. I guess im gonna go ahead and pay the 200 for a new one.
