I don't really need it since I want to swap a S12 speedo cable inside it, which is mechanical, but i do need to take the old S14 speedometer out by any mean so i can slide my S12 cable inside the gear. I found this picture while i was looking on the net:
And this is the assembly according to NISTUNE:
25010Y would be the sensor
32703 the pinion
32703E the ring lock which i guess hold the pinion to the sensor
I was thinking about using a dremel and take it out by cutting it in pieces but is there any easy way to take it out? mine is litterally stuck inside it almost like if it was press fitted inside.
