Having idle problems with an rb20 in a s13 >help!!!!!
SIL-LINE
Car: S-13 With RB20det
hey guys
I'm having a problem with my aac valve, it makes my car rev up by itself (up to 3k and stays idle there). when the aac is unplugged the car idles perfect .i just ordered another aac and installed it yesterday, same thing.
can anyone help me out ????
Cpt_Impossible
Car: G35 6MT
Is the ECU throwing any codes? Is the Throttle body clean? are there any vacuum leaks? There is also a part called the idle control valve or soemthing like that between the intake mani and the block, its hard to reach but you can see vacuum lines going to it. A common problem on the RB20's is that the spring inside comes loose and causes the car to idle super high, mine used to idle at 1800 before I hooked the spring back and cleaned it out. The other thing is, whenever you mess with any of the idle controls reset the ECU, the FSM has a process outlined.
Cpt_Impossible
Car: G35 6MT
http://www.skylinesaustralia.c...50&hl=
SIL-LINE
thanx Cpt
ill try that tonight ........ ill let you know what happened, tomorrow
WheelsDos
Car: 1996 s14 rb25 1995 s14
SIL-LINE wrote:hey guys
where did you order it from i am desprite i need one asap
SIL-LINE
i got lucky a friend of the sil240 had an extra one and i got it from him.....
but if i fix my car and it turns out it wasnt the AAC then ill sell you one...
i dont think its the AAC though, i get the same problem from both of the AAC's when they get plugged in..
SIL-LINE
Cpt_Impossible wrote:Is the ECU throwing any codes? Is the Throttle body clean? are there any vacuum leaks? There is also a part called the idle control valve or soemthing like that between the intake mani and the block, its hard to reach but you can see vacuum lines going to it. A common problem on the RB20's is that the spring inside comes loose and causes the car to idle super high, mine used to idle at 1800 before I hooked the spring back and cleaned it out. The other thing is, whenever you mess with any of the idle controls reset the ECU, the FSM has a process outlined.
hey cpt i tryed the IACV > idle air control valve > cleaned it put it back on and the same thing is happening........
it only starts to rev up when the AAC is plugged in, as soon as i unplug it idles just fine ........
do you guys know if there is someone else with this problem or has had this problem and fixed it...let me know
thanx
Sil240
Car: Nissan S13 "The One Cam Wonder"
By the IACV you mean the Air Regulator under the T-body right??
It still didn't work?????Then its gotta be the wiring.Pull up the FSM and start probing.Get a multimeter or if you want you can borrow mine this weekend.
Also you going to Moroso this weekend?There's a Z meet at Dave and Busters too
SIL-LINE
yo sil240,
bring you ECU's so that i can test if its the computer, so if that doesnt work then definitely it's the wiring
But guys i've been looking around online for cars with this problem and i havent found a solid answer!!
can anyone else with this problem or that has had this problem please let me know so that i can truobleshoot it!!!!!!
thanks guys
Sil240
Yeah I'll bring the ECU's over but..
WheelsDos
if y
SIL-LINE wrote:i got lucky a friend of the sil240 had an extra one and i got it from him.....
if you want to sell it let me know email me at [email protected]
SIL-LINE
hey guys
other than my little problem of the aac, I figured i would find out if my swap was succesfull, i let it run with the aac disconected and i moved the car around i let it sit and there is no overheating, no vale tick, sounds great!!
all i need now is to finish the dump pipe and connect the tunabi exhaust...
although im still worried about the aac problem, i fiigure it had no problem unplugged so ill drive it like that for now until i can figure out the deal with it!!
so if you guys get any ideas , let me know....
im going to post my pic of the motor when i get it cleaned up..
thanks guys
Sil240
Chris you are a lazy bastard!!!!Take your culo to radio shack go buy a multimeter.
http://www.radioshack.com/prod...earch
Test the AAC wires.I found the that my Maf grounds are shorted.
You already have another AAC valve which I know worked. Mo's car idled.You tried my MAF. Which worked just like your MAF.Stop trying to throw parts at it.!!!
Do you really think another MAF and another AAC valve will magically make your car run?
If you need the FSM I will re-load Adobe on my computer so I can read you the wires.
ripracer
Car: 01 Dodge Ram & 91 s13 hatch
Did you ever find the problem? My car has similar symptoms. Crank it up and it jumps to about 1900 says there for about 2-4 minutes reaches operating temp. and starts fluctuating from about 1100-1900 tried unplugging the AAC nothing, no codes, tried two MAFS, no boost leaks, and have clean the throttle body.
What is the FSM? I'm up here in Cntrl FL just got the car and would love to get it running right. Just bought a multimeter to start probing, but don't now where to start.
SIL-LINE
still havent found the problem.
download the FSM and start playing with the multimeter , that might work
when you disconnect the AAc what happens??
k4rr
Car: 89 dodge ram truck
I have the same issue.......
You guys ever fix it?
guyuenvy
k4rr wrote:I have the same issue.......
Sil240
yeah
i fixed it , it wasnt any of the problems you guys had it was a wiring problem but i had the same simptoms .
i bought a new harness and sent it to carl h and it works wonders ......
(sil-line)^^^^^
