kentai3838 wrote:Is it thermostat issue too? Any pointers?
Certainly sounds like it!
leo1998 wrote:On those cold cold days try putting cardboard in front of your radiator, that should help.
That would help warmup, but it'll still drop its temperature too far while running. You'd have to keep putting it in, taking it out, etc. to keep it at the proper operating temperature. By doing so to any extent, you'd only be imitating what the thermostat is supposed to be doing anyway
For your codes, click here for
P0506 and
P1456. You'll probably care more about P0506 initially since it will (should) fix your idle problem.
