nismo1003 »
https://forums.nicoclub.com/nismo1003-u8632.html
Mon Dec 08, 2003 4:25 pm
when it is cold , it takes maybe couple times to crank it up, when cold it takes maybe take less time, but till it is hard to crank it up. I am thinking these may be the problem cause? let me know what you think?
Injector leaking ? - would that cause alot of problem if it really happen? how can I tell if it's leaking? how can i test it?
Injector not working right - I got some 370cc regulate by the E-manage, but not sure if it works ? can I test if it's working properly ( testing the voltage or pluse right?)
MAF- I put mine before the compression side ? maybe because of that?
IAVV - I route that after the compression side? maybe because of this?
sparkplug - I got some NGK 1 step colder plug , would that be a problem too?
Timing - would that be becasue of my timing off a little?
I rev to 2000-3000rpm in driving condition, the car didn't want to go but when it hit boost , it ran so smooth no backfire the Rpm drop back to 2000rpm, it start back fire like crazy? what does that tell me? i know it is running rich , Is it because the injector leaking or not reuglation (e-manage)right?
my setupE-manageT3stock MAF370cc injector1 step colder ngk plug
