Having electrical and horn issues!!!
Mikey_ZX
Car: 91 Infiniti Q45 1st Gear Start
94 Nissan 300zx N/A
2008 Chevy Aveo 5
2013 Toyota Venza Limited AWD
My 93 J30 has been acting funny electrically, sometimes the horn will randomly go off as a long stream, and there will be no way to turn it off unless I disconnect the battery, really really irritating. Another issue is that my hazard lights stay on simultaneously when parked or when driving, and those won't shut off either unless I disconnect the battery. Also, the trunk will open at random times while in park or when driving. Has anyone experienced these problems??? I have a guess as to that these issues might have something to do with the alarm on the J30, wanted to know if anyone has had these issues and if disconnecting the alarm will solve these problems. Does anyone know where to disconnect the J30 alarm???
yodawill2000
Car: 94 Infiniti J30
Very strange , But I can assure you the alarm wont open the trunk !!
But the keyfob will !!
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
Okay disconnected my alarm today, the control module is connected on the drivers side nearest the radio, a relay is also located under there. I'm going to just drive the car and see if the problem persist. As far as my trunk opening randomly, I have another guess that one of my door locks is probably on its way out. Thanks yoda for replying! In regards to the keyfob, I haven't used the keyless remote in years!
yodawill2000
Is it still on your keyring ??
I was thinking if a keyfob was going Bizzerk it could do everything you mentioned.
