nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Tue Apr 03, 2012 12:23 pm
Its probably your master Cylinder. Pushing in the slave cylinder like you did should have no ill effect. The clutch system is hydraulic, pedal pushes master cyl, which pushes brake fluid through the lines to the slave. The slave pushes the fork which is attached to a pivot, which pushes a bearing to the little fingers on a pressure plate. Nothing mechanical about it.
I would replace both master and slave, cause when one goes out, usually the other is right behind it. After replacing, bleed the system, cause air in the system will cause a spongey pedal, and is definitely no fun.
