i have followed the wiring for an sr exactly as stated in
http://srownersclub.com/faq/index.asp ... i had the car running pretty good on the stock computer. But then i had got stuck wit the car cause it wouldnt turn bak on .. so had it towed .. check the fuses under the hood. nd the 25a engine control fuse was burnt .. put a another in and it blew a again... fuel pump not turning on. nd no spark.... opened the ecu and found it burn on the circuit board on pin # 45 which is for the ignition.. also just making sure it say 99% the same as sr wiring wat is the other 1 % thank you.... ne ideas would be great ...
