krayton »
https://forums.nicoclub.com/krayton-u8223.html
Mon Mar 15, 2004 2:24 pm
2. the rpm signal goes from the transmission through the engine harness then goes into a plug near your fuse box. from there it rides in the internal harness. so it doesnt go through the f3 plug. so just trace it off your transmission and use your fsm to plug it in.
3. the engine light is in the f3/m63. it basically goes from the ecu to the gauge cluster. so all else fails you can just run a wire from the ecu to the cluster.
