Having a problem with injen intake staying on
toledo240
I need help with my intake. Recently roads are feeling way bumpier with new springs and shocks. Now with that, Im having problems with keeping my air intake filter on. It leaves me strainded in the middle of a road. One time the filter fell off at a light and My car just would not budge! It has fell off many times no matter how tight I get the fasteners on. Injen only put One spot where you mount the intake itself to the car . Im all ears in hearing what I can do to stop this from falling off.:help
pr240sx
Change the connectorsClean the tube with some rubbing alcohol. You may have some oils residue on the connectors that you are currently using
quiksilvia
Car: 95 s14 se
get a new clamp, make something
ColumbusDrift
Car: 96 S14 KA24DET
Hey, just take some of that sheet aluminum in my garage under my workbench and make a bracket by using a drill, washers, nuts, and sheet metal snips and make a custom bracket to hold it together. You have my permission to use whatever is in there to make it work. Hadi will help you also if you need help.
mewt240
Car: multimedia artwork
speaking of injen intakes, where can I get a replacement hose adaptor from the TB to the tube?
