having a overheating problem with my sr20det
jeffdetty23
Car: 1990 se 240sx with sr20det swap
my car stays at about the middle of the gauge in town..but on the highway it will climb almost into the o s*** area,,i changed the cap..the radiator and over flow are filled to the required levels..i'm planning on changing the thermostat..but wanted to find out what else it possibly could be..trying to get others opinions..thanx for any feedback
AZ89two4Tsx
Have you tried running it w/o the thermostat?
zacmil
Car: 1989 240sx
2000 Mitsubishi Eclipse GT
I could be completely off in left field with this because I don't have much ecperience with Nissans but I just had a similar issue with my eclipse. I flushed the radiator and replaced the thermostat before I decided my problem was electrical. Then I ran some new ground wire. After alot of head scratching I found out that the alternator was putting out about half as much voltage more than it should and that was causing everything to go crazy. Just something to think about.
kouki munster
Car: 97 base 240
My sr does a similar thing, does fine aroud town but hit the interstate and the coolant temps start to hover just over 200, which makes me nervous.
I have noticed that the temp won't get up as high if I only go about 60 which makes me think that the water pump is beeing over driven(already a know issur on sr's) and causing the coolant to circulate to fast. So, I figured once I got some spair monies I would pick up a set of under drive pulleys, and throw on the one for the water pump and see if it helps the issue.
Not sure if this will solve your issue but it might help.
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
I had a similar thing as well. This is what I did to combat the rising temp while on the highway. I replaced the coolant to 50/50 Prestone.*make sure you have replaced the water pump*Replaced thermostat w/ a Nismo (SR) thermostat.Aluminum rad w/ a good set of fans + Derale thermostat fan controller.*invest in a radiator cooling plate*My
