All of it. And I mean ALL OF IT.str33tprintz wrote:Also :-blacked out the high beams ( not necessary with hids) -Painted the interior trim -Installed blue mood lights with switch and dimmer -All new audiobahn system -Speakers are blue and backlit on switch -Blue NOS base tube (way better than a box in the trunk, sounds better too)-Smoked the tails a bit (need more)-painted center tails, drls and corner lights black
E7-S14 wrote:whats wrong with all the lights on your car?
ummm... Readzenkistic wrote:
your front end would look more attractive if you left the stock corner and turn signal lights intact ( DON'T PAINT THEM BLACK) and retrofitted LED's in them, leaving the stock (NO BLACK PAINT) feel.str33tprintz wrote:
ummm... Read
Hahaha.simmode1 wrote:I was thinking of doing some kind of Audi styled LED mod, but wasn't sure if it would turn out ghey or not. Thanks for the confirmation!
Do not want.
All this right here:
Finally I'm getting some constructive criticism, keep them coming. To tell you the truth I had no idea how it was gonna look. And I'm not convinced either but I like doing things no one has ever done. Then I weed out the bad modifications and reverse them.E7-S14 wrote:
the way you did that by blacking out those lights looks horrible.im not gonna lie.
That would be the next step before deleting them entirely if its still not satisfactory. I'm just gonna let it ride for now, until the retro fit is done. Because I am replacing all of the lenses then anyway. Just trying new things and annoying some NICOnauts with my blatant disregard for the conventional way of modifying my car.svairman wrote:interesting idea, i probably would of taking it apart though and painted the inside of the lenses.
I decided to paint the actual cover because the original was ridiculously pitted and cracked from what i donno. the previous owner must have lived on a dirt road and drove behind trucks for years. radical solution to a simple problem I know but I'm getting clears soon enough anyway.kc240guy wrote:I woulda made the whole light fixture an led panel instead of blacking it out. I also woulda left the high beams alone so it looks normal and just not use it. I think led is cool, it just needs re thought. Car is clean, I've seen a lot worse.
Autozone. Great product. Bright as hell, can easily be seen at daytime.LBC.S14 wrote:where'd you get the LED's for the corners?
i don't think its the unconventional thinking that's annoying people, some of the ideas could actually look pretty interesting. Its just some of the execution looks cheap and shotty. Like a 16 with a rattle can did itstr33tprintz wrote:
.... trying new things and annoying some NICOnauts with my blatant disregard for the conventional way of modifying my car.
