+1NSRsheets wrote:Sounds like a vaccum problem. Check the intake and make sure everything is hooked up and tight.
this is now also located in the 350Z FAQ & General Information - directory thread that is stickied at the top of the forum.
Water and soap will only tell you pressure leaks not vacuum... Think before you speak.R350Zz33 wrote:if it dosent work u can try checking for leaks by spraying water and soap mixture on the hoses
+1 lolxjmxstac wrote:Water and soap will only tell you pressure leaks not vacuum... Think before you speak.
he means wellxjmxstac wrote:Water and soap will only tell you pressure leaks not vacuum... Think before you speak.
