^^ heres a pic to help understand what he's saying...sviellvoicae wrote:hey whats up man? anyways about the wheels and off set here is the deal the off set is how far away the center of the wheel is from the front of rear of the rim. - offset means the center of the rim is behind the face of the rim and + offset means the center of the rim is in front of the face of the rim. simply what i did was put the wheels on then measured how far they were from the lip of my fender then got that size of spacers.
dont know if that makes any sense but it does and my head lol..... good luck man let me know if i can help.
gah!k00laid83 wrote: i kinda dont want to roll the fenders!
yupk00laid83 wrote:well then i'll just flaten that lip today when i work on it! hey thanks adrian for all the help! so would you use the 30mm front spacers or the 25mm rears for the best flusness then
Dude with a +42 offset on a 240, it may clear everything but you must have sunken battleship syndrome. S chassis +42 offset = FAILslowvia wrote:i believe mine are 17x8, im running 235/45/17's with a good 2.25 inch drop without any problems
hell yea there is a difference man! good thing im gonna order those 20mm spacers and that should put my wheels at +19 hey man thanks for the pic that helped.esahuque wrote: Dude with a +42 offset on a 240, it may clear everything but you must have sunken battleship syndrome. S chassis +42 offset = FAIL
I have 2 pics for ya
1st is 17x8 +40.
2nd is 17x9 +19, you can defiantly see the difference
Modified by esahuque at 6:48 PM 7/9/2008
hey thanks adrian and im going to lower the car with coilovers but it wont me as dropped as some of the other cars i've seen here...and the reason im keeping my rear tires is because they're like new and they are pirelli tires so i was hoping i can still use them...will i still have to roll the rear fenders though?adrians_s13 wrote:hey, I got your email man.
Since you said you wont be super dropped, you should be fine with those sizes. Just know that without camber (from the drop), at stock height or at a very subtle drop, they might look like they stick out a bit, but nothing too crazy.
overall, you're good to go with those sizes... I'd prefer maybe a 245 in the rears max though... but that's my personal preference
