1unar3clipse wrote:Also...Bypass the clutch block if you haven't already afterwards it wont take 3 hours to bleed, plus it feels stiffer to some after bypassing it.
Myself and a few others have only told him a whole 50 times to remove it before buying things he doesn't need. I don't know if he has removed it yet or not, still.
Edit: My bad, i got you confused with a different person with the same same problems. Bleed it first, take the damper box off if you haven't already, and you should be able to bleed it in 5 mins tops with 2 people. Keep the fluids topped off, and make sure to squeeze the salve cyl boot. Mine was ****ed, but the fluid stayed in the boot, therefore i didn't think it was the slave. If all else fails, replace it, but only after damper removal.
Modified by LayNLow240 at 6:30 PM 9/7/2007
