Have to do it..
Exar-Kun
Car: 2005 350Z
This is the best picture anyone has ever take of my car..
yeah, yeah..its not THAT pretty, but dammit, I love her.-Chet
crzycav86
Car: 93 Nissan 240SX KAT
yyaaarrrgggg... matey.
That thar ship be the pirate 240.
Pure function, baby.
Nice stuff there Chet.
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
crzycav86 wrote:yyaaarrrgggg... matey.
LMFAO!!!
chmercer
you should try to trade that hood for one with no vent, and get the uras hood louver and stick it on further back. thats my master plan anyway. iirc that vent is in a stupid place on 240s, like right over the radiator if im not mistaken.
your car probably handles better than mine regardless of the fact that ive probably put way more cash into it, haha! lovin it chet
GhostDriver
Car: 1991 Nissan 240SX RMS13
Looks great to me. I can dig it.
turtl631
Car: S14
Cool, I'll have to keep an eye out for you. Are you happy with how it handles for now?
Exar-Kun
Car: 2005 350Z
Charlie: the vent sits just far enough back you can feel hot air come out of it when the electric fan turns on, so I'm happy with it I would like it to sit about 2" further back though, the only problem with this idea is that water could get on the pulleys if it weas left out and rained enough :/
Yeah, I love the way it handles. Doing the math paid of in spades on it, as a few of the SEDA guys can attest. The PS2's are sick grippy, and matched spring rates and shock dampening make for smooth, but quick transitions. Also the slightly lower front v. rear stance helps remove the slight bit of understeer it had, not I can feel the front push just a tad before I feel the outer rear start to lose grip if I put more throttle into it...very nice and predicatable.
Thanks for all the compliments guys.
It's still a work in progress. Hopefully I'll ge tthe C/F fenders and such put in next month, allong with the solid rear subframe and Battle Version rear link setup...mmm...
-Chet
240marcuSX
Car: E34 525i
E46 M3
your car is very nice man, looks sortof like the one in your sig.
do you have a list of your mods anywhere? id like to see what it took to get 165 rwhp na.
nismofly
Car: 89 Nissan 240SX Hatch
that picture is with the RS*R springs right?
that now i know what mine will look like...
he has a website:
http://www.240sx.org/atlanta/chets_s13.htm
Exar-Kun
Car: 2005 350Z
Yeah, but that website is horribly out of date :p
Mod list:
1993 240sx SE mod list:
Engine/Transmission• Apex-I Intake cone w/MAF adapter and 2.75” MAF to throttle body piping from Injen• Hotshot Header• 3” resonated test pipe• Apex-I N-1 single 80mm cat-back• JUN 11.2lb chromoly flywheel• ACT six-puck clutch with HD pressure plate• Enjuku Racing aluminum driveshaft• Nology Plug wires and Coil• Unorthodox Racing under drive pulley• Flex-a-lite electric fan• Koyo aluminum radiator• NISMO thermostat• NISMO transmission mount• NISMO SS clutch line• KAZAMA engine mounts• Z32 Fuel filter• B&M short shifter• Apex-I S-AFC• 180sx 6-bolt LSD• JWT cams• JWT cam gears• KA24DE.com Supertech® Ti retainers and chrome-silicon valve springs• Walbro fuel pump• 370cc injectors (Nissan sr20det OE)• Garage Defend carbon fiber GT cooling panel
Chassis• Apex-I N-1 front strut tower bar• Cusco c/f rear strut bar• Tanabe front under-brace• Battle Version front t/c rods• NISMO front LCA bushings• Battery relocated to trunk w/aluminum battery box• NISMO steering rack bushings• Aluminum sub-frame bushings
Suspension• Suspension Techniques sway bars• RS*R Down springs (3kg/mm)• KYB AGX dampers
Brakes• Goodridge SS brake lines• Powerstop cross drilled rotors• HAWK HPS pads• ATE ‘Super Blue’ synthetic brake fluid
Interior• S14 grey cloth seats• S14 manual seat belts• Autometer dual gauge pod• Autometer oil pressure and water temp sport-comp black gauges• NISMO black aluminum shift knob• Custom black w/blue stitching e-brake and shift boot• CUSCO blue spin turn knob(e-brake button)• Sparco carbon fiber pedal covers
Exterior• VOLK/RAYS Gram-Lights 17x7.5 30mm gunmetal wheels (5)• Michelin Pilot Sport PS2 225-45-17 91Y tires• C-West intake headlight cover• ViS Carbon Fiber vented hood• GTP/C-wings carbon fiber hatch with Lexan rear window
Miscellaneous• NISMO exhaust hanger bushingsNot Installed Yet
• NISMO FPR(22670-RR580)• Essential forged chromoly SCM435 clutch fork pivot• LS automotive aluminum steering bushing• SPL parts Z32 SS front brake lines• Cusco oil catch can• Moroso fuel pressure gauge adapter
Ceptos
Car: 95 240sx
have to say ive always liked the look of black on red. the alfa's in the touring car championship pull it off quite well. another look ive always liked on the s13 is when the roof is painted black in combination with the carbon hood and possibly a black trunk lid or wing, any plans for the paint job? impressive list of mods btw, ill know who to ask when i go to build my na ka =)
Exar-Kun
Car: 2005 350Z
Yeah, the roof will be sprayed black....
C/F front fenders are in the list to do, as well as 11.1-1 pistons (custom spec if I can get them made, otherwise it'll be 10.7-1)
the trunk is C/F, so it's black too :pYeah, hit me up on the NA KA, I can tell you what to buy and what not to waste your money on...
-Chetyes, the pic is with the RS*R springs
turtl631
Car: S14
So even with the upcoming adjustable pillowball arms, you plan to stay with teh RS*R down springs and KYB AGX? I'd like to drive something like that and compare it to the typical 240 with stiff jdm coilovers, staggered wheels/tires, and adjustable arms. Do you still have your full interior? You seem serious about weight reduction...
crzycav86
Chet: I'm wondering if you felt any improvement with the 370's/safc..?
Exar-Kun
Car: 2005 350Z
Yeah, I like this spring and shock setup, with the Bars, and the upcmming pillow mounts, it's more than stiff enough.
No interior from the B pillar back...I stripped that out long ago :p All that's back there is some wiring to the lights, my battery, the rear STB and some of the 'hard' insulation...
the 370ccs were more of a "going to need" when I get the engine build kind of thing, and helped a bit with keeping injector duty low with the cams and stuff. the S-afc let me tune out 4-8hp across the powerband before the cams, only a few more after (like 1-2)...
Overall, I'm happy with it...
-Chet
If you're in atlanta, I may be taking people for rides at the Gwinnett county fairgrounds event...
240marcuSX
Car: E34 525i
E46 M3
geez, thats alot of carbon fiber, do you know how much your car weighs?
and i wonder what the power output will be like after the compression change, keep us updated, as ive been heading in that direction for a while.
hannibal
Car: Red Line to Glenmont
Glad to finally see pics and mod list.
I'm curious, any idea of what the car weighs now?EDIT: ^ What he said
240marcuSX
Car: E34 525i
E46 M3
oh yeah, and also, how about doing us all a favor and run it in the 1/4 so we can know how much faster than us you are.
Exar-Kun
Car: 2005 350Z
ACtually, once I get a weekend free, I'll be removing the A/C system and seighing it, so I'll know for sure.
My bet is around 2400lbs....
Chad says 2300-ish....
We'll see. It's about 100lbs from the hood, hatch, and drivershaft, pulley, etc alone... I have no idea how much the damned A/C weighs.
Drag strip time is comming....I'll post the ET/Time-Chet
turtl631
Car: S14
Your rejection of the usual 8 kg F/6 kg R JDM coilovers in favor of the softer of RS*R's spring offerings and mass market adjustable shocks continues to blow my mind...you have a very cool and different s13.
Exar-Kun
Car: 2005 350Z
THanks. If you'll be at Souther Fried Slides or "The Untouchable" Drift events, I'll be there, as well as the 240's Buford Dam meet...
You should come by! We'll talk shop and **** all day. Just bring me some diet coke and/or vodka.
-Chet
turtl631
Car: S14
I would love to come and shoot the ****, but I just go to school here...I'll be back in chicago pretty soon, and then studying abroad in fall. I'll be in ATL in spring again, and hopefully I'll be able to pick up another S14...no more retarded stupid 20 year old with first car crashes into a cliff experiences AutoX and HDPEs only from now on.
Exar-Kun
Car: 2005 350Z
Hahaha. Cool. Well, if you get a chance, hit em up or PM me and we'll grab a beer or something.-Chet
SmithSR
Car: 240sx
Chet, wow, I look at your mod list and all I see is an impressive list of "I wants" for my car..I can't remember you ever talking in depth about your car. Why'd you wait so long!?!?
Exar-Kun
Car: 2005 350Z
Smith: same reason you don't really talk in depth about yours...it's never really finished!
I just got a nice bump in pay at werk..should provide for lots of stuff shortly...
Also, If I saw your list, I'd probably have an equal ammount of "I want"s....haha
Thanks for the compliments all. The work continues!
Also, smith..I'm sure you knw this, but I'll throw it out anyways..
Nitto is owned by Toyo...its why you can't carry -both- for retail selling...go figure. It
Nismo_Freak
turtl631 wrote:Your rejection of the usual 8 kg F/6 kg R JDM coilovers in favor of the softer of RS*R's spring offerings and mass market adjustable shocks continues to blow my mind...you have a very cool and different s13.
One of Chet's better personal features is that he believes in practicality.
Chet, given what I yanked out of my S14 ... I'd estimate your car to be in the 2400 range if not high 2300's.
My goal for the coupe is 2400 lbs. w/o getting too far into it, this time I have a 100 lb. advantage with the chassis alone.
chmercer
dont forget the best weight reduction..
Exar-Kun
Car: 2005 350Z
ACtually, I dropped 10lbs off my own frame in the past 4 weeks...
Alan- Yea, I'd love to see it sit around 2300lbs..I'm not really done yet, obviously. If I could get it to 2200..that's be uber sweet. Thanks for the compliment man.
-Chet
chmercer
is this your street car? have you considered gutting the door panels, cutting out the speaker deck, things of that nature?
