727G35 »
https://forums.nicoclub.com/727g35-u290021.html
Fri May 21, 2021 6:54 pm
I UTFSE. Youtube its okay, but the videos I find jump around a lot. The only way for me to get into reverse is by starting in reverse and it kicks right into it. Going forward seems fine, except the clitch will randomly get stuck to the floorboard. I have to put ny foot underneath, lif and pump repeatedly until theres a enough pressure to engauge going forward. Im glad my job is a straight thru a big highway.
What are the steps?
4 jack stands
Driveshaft off
Drain oil - draining diff also (was welded and came apart)
Remove transmission mount and pit jack underneath
Remove housing bolts
Remove crank sensor
What am I missing?
