have some spark
civics91
Car: cars,cars,cars
ok guys i have spark on 1 but none of the rest spark whats going on is it my ground ??????????????????:help :help :help :help :help :help :help
civics91
Car: cars,cars,cars
ANY ONE ???
civics91
Car: cars,cars,cars
????? come on guys i want to drive my babie and this is holding me up i am about to cry u dont want that
Cyberkreig
Car: 1993 Nissan 240SX SR
You have the wrong ECU. Where did you buy your motor?
civics91
Car: cars,cars,cars
zerolift i have a black top s13 motor what ecu do i need code number
Cyberkreig
that is dependant on the year of your blacktop motor.
ecu J7 is for the type X motor only. ECU's 61,62,63 E5 and E6 are all just about interchangeable.
civics91
Car: cars,cars,cars
i jave a j4 i think
Cyberkreig
I have never run into a J4 ecu. If i had to guess, I would guess that is the 180sx type X 1997-1998 Blacktop SR20DET Automatic ECU
I would try to contact your vendor to try and swap ECU's. They also may be more knowledgeable than I. Quickest way to find out is to swap ecus with a friend if that is available to you.
civics91
Car: cars,cars,cars
so i need a 61,62,63 one of then right it will work fine
civics91
Car: cars,cars,cars
i will have to go down there and get it thank god i only live 45 min from them
Cyberkreig
best of luck. I'm going to the beach for the weekend, but i'll be back sunday night, let me know how it went.
civics91
Car: cars,cars,cars
but the 61 is for a red top i thoght u cant use a redtop ecu with a black top motor
Cyberkreig
it will work. It just has a slightly older software version. Ideally you want an #E5 - 1994 to 1996 180SX Blacktop SR20DET, Manual
but any that i listed should do the trick.
civics91
Car: cars,cars,cars
what about the e6 ?
Cyberkreig
#E6 - Jan 1994 to Aug 1996 180sx Blacktop SR20DET, Automatic
as a rule automatic and manual ecu's are interchangeable
civics91
Car: cars,cars,cars
ok thanks for the help i hope to get her running by 4 pm then on fri so i can go out and have fun
Cyberkreig
hey, whatever happened?
civics91
Car: cars,cars,cars
well i think my timing is off now so i am playing with it now on the cas what mark do u use to time it with ?
DriftBandit
Car: this is my 3rd 240sx
Go to http://www.phase2motortrend.com they have directions on how to manually set your timing. Are all of your coil packs good?
I had the same problem, The shop gave me the wrong ecu, Did you get the right ecu yet?
Good luck.
civics91
Car: cars,cars,cars
she runs and runs good
DriftBandit
Congrats:ylsuper
By the way, what was wrong?
civics91
Car: cars,cars,cars
the ecu and my timing
